Číslo článku : 00382148 / Poslední změna : 09/07/2026Tisk
    Compatible outputs of the devices required when supplying power to cameras with a DC coupler
    The compatible outputs of the devices required when supplying power to cameras with a DC coupler vary depending on your model. Check the compatibility tables below and then use a USB Type-C® cable (USB-C® – USB-C) and a USB PD (USB Power Delivery) compatible device, such as an external power supply, that are compatible with the required output. If you use devices that do not meet these conditions, it may not be possible to properly supply power.
    Note: For information on the compatible outputs of the devices required when charging or supplying power to batteries (NP-FZ100, NP-SA100), see the Related Articles.
    When supplying power with a DC coupler (DC-C1, DC-C2)
    The illustration shows the coupler's connection plate inserted into the camera's battery slot and the coupler and an external power supply (USB PD compatible) connected using a USB Type-C cable (USB PD compatible) to supply power to the camera
    Compatible outputs of USB PD compatible devices (USB Type-C cable and external power supply)
    • ✓ Available
    • - Not available
    Under 65 W At least 65 W / Under 100 W 100 W or more
    DC-C1
    DC-C2
