Číslo článku : 00369684 / Poslední změna : 20/01/2026Tisk
How to play 360 Reality Audio music using the Amazon Music Unlimited service (for soundbars, home theater systems, and wireless speakers)
    To play 360 Reality Audio music using the Amazon Music Unlimited service, you will need to enable the Amazon Alexa feature in the Sony | Music Center app. You can then use either the Amazon Music app or voice commands to play music.
    Before you start
    • This article applies to specific products only. Check Applicable Products and Categories for details.
      Poznámka: For headphones, refer to the
      following article: Frequently Asked Questions about 360 Reality Audio (Headphones).
    • You will need an Amazon Music Unlimited service membership to play 360 Reality Audio using the Amazon Music app.
    • If you connect the audio device and smartphone via Bluetooth, you can play music with 2-channel audio, not 360 Reality Audio.
    How to use
    1. Install the Sony | Music Center app on your smartphone.
      Poznámky:
      • If you already have the Sony | Music Center app installed, make sure it's updated to the latest version. For details about the Sony | Music Center app, refer to the Sony | Music Center website.
      • Make sure the audio device is also updated to the latest firmware version.
    2. Follow the on-screen instructions to complete the initial setup of the Sony | Music Center app.
    3. In the Sony | Music Center app, connect and set up the audio device and smartphone using the same Wi-Fi network.
      DŮLEŽITÉ: During the Sony | Music Center app setup, the Amazon Alexa Setup screen will appear and urge you to register the device. Do not skip this step.
      Poznámka: You can choose any name for your Alexa device on the Amazon Alexa Setup screen, but we recommend using the following options to increase the accuracy of the voice recognition:
      For English
      • For HT-A9: Home Theater
      • For HT-A7000, HT-A5000, and HT-A3000: Soundbar
      • For SRS-RA5000 and SRS-RA3000: Wireless Speaker
      For German
      • For HT-A9: Heimkino
      • For SRS-RA5000 and SRS-RA3000: kabellosen Lautsprecher
      For French
      • For HT-A9: home cinéma
      • For HT-A7000, HT-A5000, and HT-A3000: barre de son
      • For SRS-RA5000 and SRS-RA3000: enceinte sans fil
      For Italian
      • For HT-A9: home cinema
      • For HT-A7000, HT-A5000, and HT-A3000: altoparlante
      • For SRS-RA3000 and SRS-RA5000: cassa wireless
      For Spanish
      • For HT-A9: cine en casa
      • For HT-A7000, HT-A5000, and HT-A3000: barra de sonido
      • For SRS-RA5000 and SRS-RA3000: altavoz inalámbrico
    4. Use either the Amazon Music app or voice commands to play music:
      • Operating the Amazon Music app
        Select 360 Reality Audio-supported music (represented with a 360 badge) in the Amazon Music app. You can then tap the source device name with either the (Alexa cast) or (Cast) icon.
        Poznámka: Make sure the Amazon Music app is updated to the latest version before following these steps.
        A screen to select a playback device on the Amazon Music app. The device is indicated as A (square icon), B (circle icon) from top to bottom.
        • A: Chromecast built-in device name (360 Reality Audio playback available)
          Poznámka: This icon is displayed for Android apps only.
        • B: Amazon Alexa device name (360 Reality Audio playback available)
      • Using voice commands
        You can play 360 Reality Audio-compatible music using voice commands. If you set the Alexa device name as recommended in step 3, use the following voice commands:
        For English
        • For HT-A9: Alexa, play the playlist three sixty reality audio on the home theater
        • For HT-A7000, HT-A5000, and HT-A3000: Alexa, play the playlist three sixty reality audio on the soundbar
        • For SRS-RA5000 and SRS-RA3000: Alexa, play the playlist three sixty reality audio on the wireless speaker
        For German
        • For HT-A9: Alexa, spiele die best of Three Sixty Reality-Audio-Playlist auf dem Heimkino
        • For HT-A7000, HT-A5000, and HT-A3000: Alexa, spiele die best of Three Sixty Reality-Audio-Playlist auf der Soundbar
        • For SRS-RA5000 and SRS-RA3000: Alexa, spiele die best of Three Sixty Reality-Audio-Playlist auf dem kabellosen Lautsprecher
        For French
        • For HT-A9: Alexa, joue la playlist de three sixty reality audio sur le home cinéma
        • For HT-A7000, HT-A5000, and HT-A3000: Alexa, joue la playlist de three sixty reality audio sur la barre de son
        • For SRS-RA5000 and SRS-RA3000: Alexa, joue la playlist de three sixty reality audio sur l'enceinte sans fil
        For Italian
        • For HT-A9: Alexa, riproduci la playlist three sixty reality audio sull'home cinema
        • For HT-A7000, HT-A5000, and HT-A3000: Alexa, riproduci la playlist three sixty reality audio sull'altoparlante
        • For SRS-RA5000 and SRS-RA3000: Alexa, riproduci la playlist three sixty reality audio sulla cassa wireless
        For Spanish
        • For HT-A9: Alexa, pon la playlist de three sixty reality audio en el cine en casa
        • For HT-A7000, HT-A5000, and HT-A3000: Alexa, pon la playlist de three sixty reality audio en al barra de sonido
        • For SRS-RA5000 and SRS-RA3000: Alexa, pon la playlist de three sixty reality audio en el altavoz inalámbrico
    5. Confirm that the music is played using the 360 Reality Audio feature:
      • For wireless speakers (models with prefix SRS-RA): The Sound Mode indicator on the wireless speaker will light up in cyan (a greenish-blue color) while you are playing the music using the 360 Reality Audio feature.
      • For soundbars (models with prefix HT-): The 360 Reality Audio icon will be displayed in the playback screen while you are playing the music using the 360 Reality Audio feature.
    Poznámka: Amazon Music Unlimited supports the following languages: English, German, French, Italian, Spanish, and Japanese.
    Related Information
    The type of audio that can be played from your audio device varies depending on the casting method.
    With the Amazon Music app for Android, you can cast music with 360 Reality Audio or 2-channel audio using either:
    • Amazon Alexa
    • Chromecast built-in
    Poznámka: Make sure the soundbar or wireless speaker is updated to the latest version.
    With the Amazon Music app for iOS, you can cast music with 360 Reality Audio or 2-channel audio via Amazon Alexa.
    Poznámka: The Amazon Music app for iOS does not support the Chromecast feature.
